Washer won't drain (not lid switch)
[quote=fairbank56;880686]I would check that bypass connection. The lid switch circuit only affects drain and spin. The clutch, motor coupler and transmission have nothing to do with the drain function.
Eric[/quote]
Eric,
You are right! It looked fine on the outside but was corroded on the inside on one side (the side with the grey wire. I can’t get the connector clean enough to reconnect. I’m not sure what to do now. My mechanical capabilities are limited to moxie and what I learn on forums and by watching videos. I think I need to connect the two outside wires. Maybe pull both the outside wires out and connect with a wire nut? If so what do I do about the middle wire? Not sure about this. Any ideas? Thanks so much
Cindy
