Maytag Washer Water Fill
[quote=fairbank56;880555]In that case, looks like a faulty temp control board. I would still verify by doing the test that I suggested. The board is $116. If you don’t care about using auto temp control, the board can be eliminated with a little wiring change.
Whirlpool 22003906 Control Board - AppliancePartsPros.com
Eric[/quote]Jumped 12 to 3 with cold/cold selected, nothing, no temp settings worked; with jumper removed, hot/cold worked. Does this mean Temp Control Board?
