Ram will not stop at top of cycle. I've replaced the top limit switch and still have the same problem. Is there another switch that might be bad?
Thanks,
Roger DIY
Your top limit switch arm is out of adjustment. Bend it with trial and error till you get the 2 click positions exactly right. This switch is the cause of many trash compactor problems. Al
Thank You. I'll give it a try this weekend. Roger
