[QUOTE=fairbank56;865848]The shift actuator does not control spin function. All it does is disengage the agitate gear when you are in spin so that the agitator does not go back and forth while basket is spinning.
Eric[/QUOTE]
Oops, you are correct, I misunderstood what was happening. It does into spin mode, but then will never re-engage the agitate gear. I will post a vid in my original thread to not hijack this one further. :o
