Washer makes loud noise like grinding
[QUOTE=fairbank56;787735]You have to lay the machine on it’s front side to get to the bottom where these parts are. Remove the belt shield to get to the nut on the pulley. If it is loose, apply some blue 242 loctite before tightening. Another common problem with this unit is the shifter. It shifts the splutch between agitate and spin mode. It is the device next to the large pulley that has “synchronous motor” written on it. You didn’t say when it makes this noise.
Eric[/QUOTE]
Eric’s advice helped me fix my WTW4800XQ1 when it was making similar grinding noises. I unplugged it, laid it on its front side (didn’t even have to disconnect water or drain lines) and found a nut on the floor under the motor. I put the nut back on and its back in business. Very easy fix. Thanks Eric!
