I have a Kenmore 80 series washer that is a little over 10 years old. Whenever the wash or rinse cycle starts the agitation start in heavy duty no matter where the control is set. after two seconds of agitation it clicks and goes into the agitation set on the control. I think the control behind the knob is what needs to be replaced. Am I correct or is it somewhere else?
Groups: Expert
The motor always starts in high speed no matter what speed is selected. Once the motor comes up to speed, the centrifugal mechanism in the motor activates the motor switch and the motor will go to a lower speed if one has been selected, otherwise it stays in high speed. Normally, this switching of speeds takes place very quickly and is not noticeable. If it's taking a long time to switch, the motor centrifugal mechanism may be sticking or the motor switch contacts may be sticking. You can take the cover off the switch to examine the contacts. Another possibility is a weak starting capacitor which is used to provide the starting torque necessary to get the motor going.
Eric
Thanks, that was the problem. I took the motor out and sprayed the switch and motor with some electrical contact cleaner, then with some electrical grade lubricant. Then I put it back in ran it and the problem has dissapeared. If it reappears I will just order and replace the switch.
