I noticed when I search for relay no. C8931505, it shows No Longer Available.
I was reading some of the Q&A with some conflicting part no.
I wonder what is the equivalent part replacement for this part. If there is a complete kit that includes the relay, overload and capacitor?
Thanks.
What is your problem, compressor no run, etc
After some diagnosis, I determined that the ptc relay is bad.
If you have a meter, I can help, but I hope you made a diagram where each wire goes.
Sure, I have a DVM. Thanks for the help.
Hold the old ptc device with the input, male, spade terminals facing you and the tab on top, pins on top. If you measure a short from the top, right terminal to the output, round compressor terminal on the other side,right and an open, or 5- 10 ohms from the same input terminal, to output, round compressor terminal on the left, you have the standard ptc device, the start terminal is on the bottom,left. If you measured 5 - 10 ohms, your ptc device is ok. If so, you can use a WR07X10051 ptc One fridg power wire goes to the overload, the other to the right input spade terminal of the ptc. If not, your start terminal is bottom, right, or if the common compressor terminal is on the bottom, then start pin is upper left.
