alanfj
#1 Posted : Saturday, May 3, 2014 5:23:59 AM(UTC)
alanfj
French style refrigerator w/ bottom freezer. There is no drain plug. The condensation(water) builds up over a period of a few weeks under the refrigerators bottom deli tray and has no where to go. This has been a problem since our purchase. It is noticeably more problematic in the summer months when the humidity levels are higher. What is the problem? My wife hates it. If is not removed it starts leaking out of the front top doors. Help!:(
alanfj
#2 Posted : Saturday, May 3, 2014 7:27:13 AM(UTC)
alanfj
Found answer common to this fridge; here it is: 041027 GE service to correct water leaking inside refrigerator. A engineering design flaw. Drain tubes freezing. Thaw out fridge or clear frozen drain tubes.:)
