klingenfelter
#1 Posted : Thursday, May 1, 2014 5:03:55 AM(UTC)
klingenfelter
Hi I have a KitchenAid KUDS02FRSS0 Dishwasher. The unit just went dark, no lights on the panel top, but the breaker is on and power is at the junction box under the unit. I took the door off and chased 110VAC to the thermal fuse. It ohms as open. I assume this should be NC. It seems the thermal fuse is bad. Do I have this correct? Thanks Keith
Another question should the thermal fuse reset after it cools down or does it simply break open permanently when to hot. If not then I assume the thing is just bad and I need to replace it.
Keith
