Kenmore/Whirlpool Series 80 Washer Transmission problems
Update & more questions!
Ok, so I ordered the agitate cam & cam follower and installed them correctly this time, and since I had a wallowed out motor/trans coupler now (damaged when the trans seized and the motor kept turning) I put a bolt in it to chuck it up to my drill so I can easily spin the transmission for testing.
What I discovered was that when the transmission input worm gear is spun clockwise, the right side tab of the shift actuator is supposed to contact the right side agitate cam tab and push it, causing the agitate cam & cam follower to separate and lift a gear above the connecting rack, pushing against an agitate spring, causing the washer to disengage agitation mode. When pushed fully, the agitate cam & cam follower lock into this “spread apart” position. So the washer is in spin mode only and agitation mode is disengaged.
And when the transmission input worm gear is spun counterclockwise, the left side tab of the shift actuator is supposed to contact the left side agitate cam tab and push it, unlocking the agitate cam & cam follower, and the agitate spring pressure will force the agitate cam & cam follower to close and the gear then drops back into the connecting rack, causing the washer to go into agitate mode. Since the motor/input is turning counterclockwise, spin mode is deactivated by the spin gears.
So my problem is, when turning clockwise, the right side tab of the shift actuator will initially contact the right side agitate cam tab and start to push it, but about halfway through it’s travel it slips off. It’s as if that right side agitate cam tab is molded improperly and doesn’t stick out far enough (i.e. the tab needs to be a bit longer). So the agitate cam & cam follower never fully separate and lock into this “spread apart” mode. The part I bought is supposed to be a genuine Whirlpool part PN 285206. My washer is actually a Kenmore 110-82881100 and those 2 parts are listed separately as PN 62580 & 62581 but I’m led to believe that the Whirlpool part PN 285206 set is equivalent. Am I wrong? Could I have a bootleg part that’s not to spec? What else could cause this problem?
Turning counterclockwise works fine - the left side shift actuator tab hits the left side agitate cam tab and it goes into agitate mode just fine. I looked closely at my shift actuator and it looks just like the photos on the web, I see nothing wrong with it. So I bent the right side shift actuator tab inward just a tad and it works better - it doesn’t slip off the right side agitate cam tab until it’s just almost at the full lock position now. But it’s not quite there, it’s about 1/32 to 1/16 of an inch off from being in full position, but it seemed enough that the agitate cam & cam follower could lock into the “spread apart” position, so I put the washer back together to give it a try.
Unfortunately, during the spin cycle I see it trying to go into agitate mode (making a loud knocking sound) so I believe the agitate cam & cam follower aren’t locked well into that spread apart position and with the vibration they’re slipping down and agitate mode is trying to engage.
Any suggestions? Have you heard of some cams not being molded to spec? I’m contemplating welding some more metal onto that right shift actuator tab (then grinding it down and shaping it) to make that tab just a bit longer but I don’t understand why I should have to resort to doing this. The shift actuator seems to fit just fine onto the big cast iron pinon gear with no slop.
Thanks,
Tom
