Thanks so much for responding in such great technical detail - this is exactly the answer I need! Sorry for the confusion about the model number. The forum software requires a model number and I did not have access to the washer when I originally wrote the question so I was forced to just look up a model number for a Series 80 washer on the internet. But my understanding is that the Whirlpool direct drive transmissions haven’t changed. My actual model number is 110-82881100 and we bought it used back around 1990. Or maybe it was 1992 as I was still in a apartment in '90.
Thanks for explaining how the guts of the transmission actually work! I’ve searched the web for this info and failed to find anything and no one has answered my post on the other site so you’re probably one of the few that truly understand it!
Regarding the YouTube video, thanks for pointing out the error in the agitator shaft part. I looked closely at the 1st part and I see how the cam and cam follower originally are oriented, and then when he skips to rebuilding the agitator shaft the 2 are reversed! I think this is why I smashed the cam to bits after my rebuild, as I followed the video exactly and assembled it in the wrong order! I did not pay close enough attention to it when I disassembled as the YouTube video was very clear, but unfortunately wrong.
I clearly see now that the agitator shaft does not have the cam and cam follower installed the same was as the one he pulled out of the transmission as you pointed out - does this mean that some models have these 2 parts reversed, or did he somehow have them reversed before shooting the video?
I’m going to go on the assumption that my original seized motor was due to lack of lubrication in the transmission as all the oil eventually leaked out. I think my shift actuator is ok as it’s just showing some minor wear and scratches on one of the tabs. I’ll put a new cam and cam follower in and run it with a drill and see how it goes. That’s cheaper than a new tranny and I really see nothing else wrong with it.
Thanks again for the expert advice!
Tom
