Our fridge doesn't cool. Compressor and condensor cooling fan are running OK. Evap fan won't run and fridge beeps every four seconds. Beeping stops when I disconnect evap fan motor. I have 12 volts to fan motor, checked when I unhook fan motor. Bi-metal and heating element have continuity. Replaced evap fan motor with new - get the same beeps and fan won't run. Next guess is, I have to have the control board rebuilt (W10219463). Core Centric Solutions says they can do it. I cannot find the control board! Everything says it is just to the left of the compressor, but all I find is the inverter. Do you have a picture or a video that shows the location of this control board? I cannot find it to remove it!
It's behind the control panel in the fridg section.
Are you talking about the temperature control board? It is in the drop down control box. I am looking for the power control board that is supposed to be under the fridge liner, but I do not see anything that looks like a control case - just the inverter. Thanks for your response.
Look at the break0own diagrams, I only see a big control board.
Your board must put a square wave out to run the motor, you have a bad board. Make sure the motor is new also.
I know nothing about this .
