Eric - I don’t know how to check for error codes or how to decipher them?
Today I changed out the Lid Lock. Finally figured out how to calibrate the new control module and did it several times. NO CHANGE same problem! It still stops at the spin cycle and quits when doing a normal wash. The clothes are soaking wet. Hit the Drain and Spin cycle and it goes thru the spin cycle okay to the end.
Guess I will change out the actuator next. I wonder if the new control board maybe defective. This high tech low quality machine is a nightmare. It’s one month out of warranty! Any other ideas appreciated.
