Okay Eric thanks. I’ll try the actuator after replacing the lid lock asm. The strange thing is it always stops at the spin cycle. Then when I dial the Spin and Drain cycle and hit Start, it Spins and then drains perfect. Doesn’t it seem logical the actuator must be working? The lid lock on the other hand goes on and off several times very erratically which doesn’t seem right. All I know is that the Computer/Control module did NOT fix this problem which was a big surprise.
