Ok, here is what I would like you to do.
With no clothes, set the washer timer on rinse with low water level and let it fill up and go through the rinse cycle. After you hear all of the water has drained out, about 90 seconds to 2 minutes, lift the lid and hold it open for about 5 seconds. Then close the lid.
If the machine goes into a spin at this time, the problem is probably in your timer. Basically, the timer has to tell the motor to pause briefly after the water has flowed out of the machine, and your timer is failing to do so. Lifting the lid artificially creates this pause and if this is the problem the machine should now go into spin mode.
Here is your timer
Replacement parts for WHIRLPOOL LA5580XTW0 | AppliancePartsPros.com
If lifting the lid and creating the pause does not work to start spin mode, please post and let’s see what else we can come up with.
Good luck
