Washing machine will not spin during rinse cycle
[quote=sidfink43;82046]Can you give us a little more information
  1. Does it spin after the wash cycle but not after the rinse cycle?
  2. Does it drain after the wash cycle and after the rinse cycle?
  3. When it is not spinning, can you hear the motor running?
  4. Does the timer advance in the spin cycle when it is not spinning?
Please provide any other info you think will help and let’s see what this tells us. Thanks[/quote]
Yes it spins after the wash cycle but not after rinse.
Yes it drains after the wash cycle and rinse cycle.
Yes I can hear the motor running when it is not spinning.
Yes the timer advances in the spin cycle when not spinning.
