Can you give us a little more information
Does it spin after the wash cycle but not after the rinse cycle?
Does it drain after the wash cycle and after the rinse cycle?
When it is not spinning, can you hear the motor running?
Does the timer advance in the spin cycle when it is not spinning?
Please provide any other info you think will help and let’s see what this tells us. Thanks
