I hear a continuous clicking noise when the compressor? fans are running. Less then two weeks old. Purchased from lowes. What's wrong? Is it still under any kind of warranty? I can still purchase extended warranty, if you think that is the best thing to do.
Thanks, pdl2
[COLOR="Blue"]What's wrong?[/COLOR] Depends what is clicking. If it is the start device on the compressor get it fixed under warranty as it could be an expensive repair. [COLOR="Blue"] Is it still under any kind of warranty?[/COLOR] It should have a one year warranty on it. |
THIS FORUM IS DEAD!!!!!!! |
considering a problem only being 2 weeks old, should I purchase the extended warranty? 2 years - $49.99 4 years - $109.99. Not sure if figures are exact.
thanks, pdl2
Sorry but I do not give advice on things like this because :if I say yes the unit will run perfectly for the time of the extended warranty. :if I say no it will break down at one year plus one week. |
You have 1 yr parts and labor----use it. But I'll suggest that you make a visual check out where the noise is emitting from......Possible a kid's toy touching a fan, etc.
