Washer will spin and drain but doesnt agitate
Need to determine if the problem is happening in both low and high speed. Put washer into service mode by first placing cycle selector to the 9 o’clock position, then press and hold the start button and rotate cycle selector 180°, release start button and all LED’s should light up. Turn cycle selector 5 clicks to the right for slow agitate and one more click for fast agitate. Two more clicks will place it in spin which I believe is high speed. If it won’t agitate in either speed, the electronic control is likey bad, if it works in one speed only, could be the electronic control or motor problem. Have you noticed if it spins in both high and low ok? The control panel is number 35 in the controls and backsplash parts diagram. To get out of service mode, press/hold start button and rotate cycle select 180°.
Eric
