Kenmore Elite Model 26922 Top Load Washer, purchased 6/5/05. On normal wash cycle, it fills completely. When it follows the cycle and goes to agitate, it becomes completely dead. It doesn't start agitating, nor is there any noise to indicate the motor has engaged. If I turn the timer to spin, etc. nothing happens. Now, if I disconnect the power for about 10s, then resume timer on agitate, it will run till competion. I checked lid switch & water fill switch, and appears they are working properly. Any ideas?
