Hi: I have a GH5184XPS5 stainless steel microwave. I purchased a 8205375 touch pad. Upon removing the old touch pad, the connector that connects the touch pad to the electronics appears different - it is wider. This touch pad was recommended by two vendors based on the model number, so I felt pretty confident to purchase. Can this touch pad be utilized anyway by leaving part of it hanging out or is there another touch pad that should have been ordered? The connector is constructed such that there is a gap at an area which allows a portion of the connector to fit perfectly.
Can someone help me with this? Thanks
