Hi.
You should check:
- the drive pulley and nut ( loose, cracked or worn out)
- belt (cracks and missed pieces)
- drain pump
- transmission
All this parts you can check from underneath the washer.
Here are the breakdown diagrams and Gearcase, Motor and Pump parts for Whirlpool WTW4800XQ1 - AppliancePartsPros.com
Post thew results.
Simon.
