Need tip to install the last of the six suspension springs. Tried coins, tried old spring. Tried everything I know except screwdriver (TO AVOID MORE DAMAGE). Any suggestions?
Originally Posted by: nancyjean Need tip to install the last of the six suspension springs. Tried coins, tried old spring. Tried everything I know except screwdriver (TO AVOID MORE DAMAGE). Any suggestions? How did you get to the springs :confused:
To expose the suspension springs, you need to remove the front panel of the washer.
