Replaced mother board and defrost termostat problem still exists ice refreezes and ice crystals forms on food
What is the exact measured temperature in the freezer?
Originally Posted by: Gene What is the exact measured temperature in the freezer?
Gene. It goes above 32 degrees when in defrost but not all the time
Replace the evaporator thermistor (on top of the evaporator). It controls the defrost cycle temperature. - The thermistor Part number: WR55X10025
Originally Posted by: Gene Replace the evaporator thermistor (on top of the evaporator). It controls the defrost cycle temperature. - The thermistor Part number: WR55X10025
Gene. Thanks I'll try that,I repair -80 degree revco freezers at work and this household refrig is kicking my butt!!!! Glenn
Originally Posted by: glennbcool Thanks I'll try that,I repair -80 degree revco freezers at work and this household refrig is kicking my butt!!!! Glenn Thanks Gene thermistor did the job!!!!
You are welcome Glenn. I'm glad you were able to fix it.
