Maytag Dishwasher MDBH989AWW2
Runs great for 3 years. 3 days ago lites stay on at 'normal' and 'heated dry' buttons (then I'd just push start) but won't run then after 30 seconds go out. Same thing over and over. Recycled power, waited, no change. Local App guy sells me a $200 control board, this is it for sure.
Remove power, Install board, power back on...same exact thing
Have 110vac to board plug in. Have 110vac to door switch (com/NO) switch works fine. Have 110vac to each side thermo button on control board. No wiring diagram.
Original board was p/n W10250166A New board is W10298356 physically and connection wise exact same.
But aparently it's not the board
Any help appreciated. I'm a retired elevator mechanic of 34 years. Pretty handy with a meter and such. Just not sure where as I have no wiring diagram. If I knew where some test points were I could figger it out. Right now with the above in order, I need to know where the signal is to start button. I'm guessing it's thru the ribbon cable with a 5v logic or similar to a start/run signal. Anybody got some pin #'s for any of the buttons on panel?
Read more: http://forum.appliancepartspros...board.html#ixzz27bgdJYDh http://forum.appliancepartspros.com
APP will not let me attach the file. Probably too big. So I put it on DataFileHost. Here it is, hopefully you can get it. Download MDBH989.pdf |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  APP will not let me attach the file. Probably too big. So I put it on DataFileHost. Here it is, hopefully you can get it. Download MDBH989.pdf thanks for the help will be able to check beyond the control board later this afternoon gotta be a valve switch or something just got all the dishes out last night appreciate the effort
upon further review: jump pin p1-12 to p1-4 starts the machine on it's way board is fine, problem is between the board and the button on panel that's all one piece with ribbon cable so here goes
What was resolution? I have same issue.
