My washer has the ATC function. ATC has 3 settinsg (hot, warm, cold). The is also a cold setting for NON ATC setting. Currently the temperature is the same (hot) no matter what selection is made in ATC mode. When I turn to NON ATC mode (cold), the water is cold. I have replaced the ATC switch and that did not correct the issue. I have been told that it could be valve in the back and have been told that there is no way the valve is the issue sice the cold works when I turn it to cold (in non ATC mode). Not sure if I should replace the valve or if I am missing something else. Any suggestions will be appreciated...Thanks
Groups: APP Team
I replaced the mixing valve. So now the switch and valve have both been replaced and the issue has not been resolved. Any other suggestions?
Groups: APP Team
Hi. Sorry for the inconvenience, it's not always easy to diagnose the problem from the distance. After double checking I think it's the ATC board Part number: 27001208
You can return the other parts. Thank you. Simon.
I bought the temperature control board and installed it today. Problem has been corrected. ATC is now functioning as it should
Thanks for all of the help and suggestions
Groups: APP Team
