2 Pages12>
walley
#1 Posted : Tuesday, July 10, 2012 7:29:11 AM(UTC)
walley
washer is not spinning when draining. put in new timer and still not working. i can push on/off and it will kick in and spin. took door switch out and wired together to eliminate that. Help!
Simon / APP Team
#2 Posted : Tuesday, July 10, 2012 8:55:37 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What is the complete model number?
Simon.
walley
#3 Posted : Tuesday, July 10, 2012 5:39:44 PM(UTC)
walley
model # 100.22722110
Simon / APP Team
#4 Posted : Tuesday, July 10, 2012 7:58:42 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Why did you bypass the lid switch? Did it make any difference?
This washer is equipped with "neutral drain transmission", witch means that washer first draining the water out then timer pausing for a few seconds allowing transmission gears to engage. When the motor restarts - the basket start spinning.
Check if the timer makes a brief stop when it's draining.
If it's not pausing - bad timer.
Thank you.
Simon.
walley
#5 Posted : Tuesday, July 10, 2012 8:53:21 PM(UTC)
walley
Will check that. I just replaced timer with new from you guys. It is better than with old timer. Thanks, will let you know
Simon / APP Team
#6 Posted : Wednesday, July 11, 2012 8:56:53 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
walley
#7 Posted : Saturday, July 14, 2012 10:18:29 AM(UTC)
walley
Simon, washer paused for 3 seconds then kicked to spin but didn't stay engaged. Shut off and turned right back on and started to spin and drain. Same after rinse cycle.
Simon / APP Team
#8 Posted : Monday, July 16, 2012 9:07:59 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the washer spin and drain? Does the laundry ready for the dryer at the end of the wash?
Do you still have the lid switch bypassed?
Simon.
walley
#9 Posted : Monday, July 16, 2012 7:19:26 PM(UTC)
walley
Yes, it will spin and drain. It doesn't spin after wash or rinse unless I push timer off then on. Will spin at end of cycle. I do still have lid switch by passed.
Simon / APP Team
#10 Posted : Tuesday, July 17, 2012 12:47:59 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please double check the model number and post the timer part number that you replaced.
Thank you.
Simon.
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Replacing a stacking Bosch Axxis+ Washer (Washer Repair)
by DonLafontaine 3/22/2024 3:59:06 AM(UTC)
Kenmore series 90 washer stopped working (Washer Repair)
by Guest 3/16/2024 6:19:45 AM(UTC)
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Amanda washer intermittently wont fill (Washer Repair)
by Guest 3/13/2024 3:48:07 PM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
Kenmore 80 Series washer, fast speed burning smell (Washer Repair)
by lwmi5870 3/9/2024 1:25:21 PM(UTC)
Opened lid to add something to washer after it started and now the cycle won’t start again (Washer Repair)
by Guest 2/25/2024 6:18:56 AM(UTC)
Maytag Bravos XL MCT Thrust washer (Washer Repair)
by EricP 2/21/2024 2:57:06 PM(UTC)
Maytag Bravos MCT Washer (Washer Repair)
by Guest 2/21/2024 12:53:32 PM(UTC)
GE Frontload Washer Spin (Washer Repair)
by mahgnibb 2/16/2024 6:13:51 AM(UTC)
2 Pages12>
