problem is frig warm(55 degrees) freezer fine for now. i have more info. J1-5 to J1-4 thermistor evaporator is 170 ohms J1-5 to J1-2 thermistor FF??? is 8K with freezer cold J1-5 to J1-3 thermistor FZ??? is 21K with freezer cold major ice build up on the evaporator coils evaporator fan spins 27 ohms between defrost terminal J9 and orange nuetral
i don't know what FF and FZ are but i do see 2 sensors with white wires coming out of them in the freezer. are these what i should replace along with the control card?
i have replaced the defrost heater 2 years ago. is the thermistor evaporator the one with the clip on the freon tube? and should i replace that? thanks for any help you can provide
Seems like the evaporator thermistor is bad,I would replace it and check your defrost heater, if black inside with a gap, it's bad.
