Unit was making noise only on high speed , low speed no noise until finally stopped working all together. upon inspection one out of 2 blower motors locked up with wires charred. should i replace both motors or is there a thermal switch that tripped saving the other motor, cant find one in diagram , hard enough finding motors. should i replace both capacitors also
