The water dispenser on my Maytag side by side has stopped working. I thought I did my homework and replaced the filter, then replaced water inlet valve. Still doesn't work. I disconnected water line at front bottom of freezer door and no water. I checked water reservoir behind crisper and it appears normal. I disconnected larger line from water inlet valve and attempted to dispense water and water came out at inlet valve. Now what, I don't have a clue!!!!!!!!
