Clemski
#1 Posted : Tuesday, April 24, 2012 5:46:44 PM(UTC)
Clemski
The ice/water dispenser stopped working simultaneously on my fridge yesterday. The panel has power (light works) and I've checked the switches on both and they seem to be working fine (I've had to replace a broken clip holding a switch before). I've also checked the wiring at the door up top at the hinge and the wiring behind the door switch inside. There is no noise or response when either the water dispenser or the ice maker levers are triggered. When I switch the light on and push the levers the light doesn't dim. Any ideas? :mad:
