This fridge is not defrosting, I checked the defrost thermostat and heater, they are working fine, I suspect the problem is the timer, can I force it to defrost to make sure that is the problem?, thank you
THIS FORUM IS DEAD!!!!!!! |
You are welcome
It sounds like the defrost board is toast since the heater and thermostat are OK.
It would be appreciated if once you get it fixed you post. Then when others search for a similar problem they will see what actually fixed the unit rather than just suggestions on how to fix it.
Good luck denman |
