Two issues:
(1) I am having the very problem you described in a previous post (pasted below):), the only difference is that I have a different model of Whirlpool washer (L5Q9544KQO). A search for this model in Appliance Parts Pros.com Discount Appliance Parts didn’t turn up a match, so didn’t have any luck finding the equivalent timer part referenced in your post. Any thoughts on how to find this elusive part for my model of machine? FIGURED OUT I MISTOOK THE S AS A 5 IN THE MODEL #. I FOUND THE PART.
(2) In addition to the timer issue, which has been going on for over a year, just last week we suddently started to notice tiny greyish flakes floating around in the tub during a wash cycle and it seems to be getting worse. It’s not coming from the clothes, but rather seems to be floating into the tub through the holes when it fills with water. I’m thinking it’s either mold from the basin under the tub or from inside the water lines feeding into the machine. The machine is at least 8 years old, but can’t be sure. We bought it with the house. Have you encountered this problem before? We have a repair person coming this Friday, but now that I have the spin problem ID’d, it seemed worth at least exploring a DIY fix for the second problem. I DUG FURTHER ON THIS SITE AND FOUND THE VERY PROBLEM WE’RE HAVING AND A FIX.
Thanks!
QUOTE=sidfink43;82436]Ok, here is what I would like you to do.
With no clothes, set the washer timer on rinse with low water level and let it fill up and go through the rinse cycle. After you hear all of the water has drained out, about 90 seconds to 2 minutes, lift the lid and hold it open for about 5 seconds. Then close the lid.
If the machine goes into a spin at this time, the problem is probably in your timer. Basically, the timer has to tell the motor to pause briefly after the water has flowed out of the machine, and your timer is failing to do so. Lifting the lid artificially creates this pause and if this is the problem the machine should now go into spin mode.
Here is your timer
Replacement parts for WHIRLPOOL LA5580XTW0 | AppliancePartsPros.com
If lifting the lid and creating the pause does not work to start spin mode, please post and let’s see what else we can come up with.
Good luck[/QUOTE]
