How do I install the handle, all trim for glass for the door on my whirlpool stove?
Originally Posted by: Adam28  How do I install the handle, all trim for glass for the door on my whirlpool stove? Adam, Here are some basic instructions : REMOVING THE OVEN DOOR HANDLE & GLASS
Disconnect power before servicing the range. Replace all panels before operating range. Failure to do so can result in death or electrical shock.
1. Remove the oven door from the range . 2. Place the oven door on a padded work surface with the front glass facing down. 3. Remove the two top door liner screws.
4. Remove the three bottom screws from the door liner.
5. Lift the liner assembly off the front glass and set it aside. 6. To remove the door handle, unhook it from the top of the front glass and remove the two door handle screws.
7. To remove the front door glass, remove the two side trim screws. Be careful not to break the trim near the mounting screw. *** If you have new door glass side trim, there will be a protrusion on the bottom of the trim, the protrusion will insert into the screw holes of the original bottom trim, and the two screws will not be used.*** Thanks and Good Luck, :) :) :)
what do you do with little black clips where do they go? ineed help
Originally Posted by: Jennifer1  what do you do with little black clips where do they go? ineed help If they are the smaller black clips Part number: AP2989728
They are attached to the inner door liner and the little tab sticks up to assist in aligning the glass to the door liner. align them evenly spaced on the sides and finish the installation.
