2 Pages<12
Markram
#11 Posted : Wednesday, March 7, 2012 1:42:11 PM(UTC)
Markram
Originally Posted by: jd1md1 Go to Quoted Post
Gene,
I figured that out. Purchased outer tub assembly to fix bad bearing as advised. I do not see any bearing, just seal like on old one. Should there be some type of bearing?
You cannot see the bearing as it is beneath the seal...
Markram
#12 Posted : Wednesday, March 7, 2012 1:52:32 PM(UTC)
Markram
Originally Posted by: Markram Go to Quoted Post
They make bearing replacement kits, and I have replaced several bearings already. I am a Sears Repair Tech, and am unsure if the kit is available online... it should be. I can look in my van and include the part number. Although I would not recommend this task for anyone that lacks experience with taking things apart.
I found the bearing kit... it includes the tools in the kit. Of course this is for the Elite and/or Cabrio.
Part # W10435302
Instructions
http://media.fotki.com/1_p,skdt...97453812306690img-or.jpg
http://media.fotki.com/1_p,skdt...82247419457303img-or.jpg
#13 Posted : Wednesday, March 7, 2012 4:18:20 PM(UTC)
Sorry, my bad. I mixed this newer model with traditional Cabrio washer. If you ordered the outer tub from APP then you can return it for full refund.
There are 3 parts which could cause such noise. They are: the pulley, the cam and the basket drive gear (#13, #12 & #10 on the diagram). You have to remove them and check the teeth and splines.
Post the results.
Adam / APP Team
#14 Posted : Thursday, March 8, 2012 2:36:12 PM(UTC)
Adam / APP Team
Rank: Administration
Groups: Administrators
jd1md1,
I have reviewed your order. The tub we sent in replacement of the first one is in route now. If you or someone is home to accept the package from Fed-Ex it can be refused and sent back to the warehouse. If you are unable to refuse the package we can also have a pick up tag sent out to you.
For assistance please call our toll free number at 1-877-477-7278 and let them know of the situation. I will put notes in your order.
Our apologies for the inconvenience.
Thank you for choosing AppliancePartsPros.com
jd1md1
#15 Posted : Friday, March 9, 2012 6:53:46 AM(UTC)
jd1md1
Thanks Gene, I though I was nuts looking for bearing. After completely tearing down and not finding bearing I removed belt shield,belt was off of cam and cut thru shield, this is what was making noise until belt came off cam, then would not complete cycles. Another weird one to add to your bag of tricks.
Bob
jd1md1
#16 Posted : Friday, March 9, 2012 6:55:33 AM(UTC)
jd1md1
Thanks Markham, I have found my washer does not have a bearing.
#17 Posted : Friday, March 9, 2012 12:52:34 PM(UTC)
You are welcome Bob. Thank you for the feedback and good luck with your washer.
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
2 Pages<12
