The drum on my Bosch machine is not rotating. (it's not the drive belt). The machine filss with water and the control panel displays all of the cycle's progress. I also here solenoid /relays working but no drum movement. I suspect the motor. Is there a way to test/inspect that the motor is bad before the expense of purchasing a new one?
Thanks in advance for your help.
