The dishwasher drains well at end of wash cycle, but will not drain ANY water at end of rinse cycle leaving 1 1/2 gallons in tub before dry cycle begins. Screen is clean and no blockages in line. Could it be the control board or sequence switch?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: rowen  The dishwasher drains well at end of wash cycle, but will not drain ANY water at end of rinse cycle leaving 1 1/2 gallons in tub before dry cycle begins. Screen is clean and no blockages in line. Could it be the control board or sequence switch? hey there have you gotten any reply to this issue im having the same problem
Originally Posted by: DGerryd  hey there have you gotten any reply to this issue im having the same problem No response. Good luck!
Originally Posted by: denman  It drains fine after wash and at end of rinse and hold. The pump does run at all at end of rinse cycle during normal wash.
Try different cycle types to see if it will do the final drain.
It is probably the timer but I cannot be 100% sure as I cannot find a service manual for this unit, |
cheers denman will do that
