AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washing machine wont fill with water to finish rinse cycle
My machine fills with water for the wash cycle, aggitates, and drains.Then the water just trickles out so it never fills. It aggitates and then drains. It has a triple valve. Could it be this or the timer or the lid switch?:eek:
Originally Posted by: kryzat  My machine fills with water for the wash cycle, aggitates, and drains.Then the water just trickles out so it never fills. It aggitates and then drains. It has a triple valve. Could it be this or the timer or the lid switch?:eek: Hello .Based on the information that you have given, it sounds like the valve Part number: AP3995044
you can try cleaning the screens out, usually it is the cold water side that is the worst, about stopping up, Thank you and good luck !
Washer Repair
