teensa
#1 Posted : Tuesday, February 7, 2012 9:53:57 AM(UTC)
teensa
It was working fine one day and then just quit the next. Has an inch of water at the bottom and no power to the panel. I opened it up and there don't 'seem' to be any blown fuses, or loose connections. Help please!
Thank you!
#2 Posted : Wednesday, February 8, 2012 3:20:24 AM(UTC)
I cannot find any info on the given model number.
Are you sure it is DU1055XTVVQ0 or is it actually DU1055XTVQ0.
Here are the parts for an XTVQ0.
Replacement parts for Whirlpool DU1055XTVQ0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Could be the thermal fuse (Item 4 in Section 1) is blown.
Remove power from the unit.
Remove the fuse and check it with a meter.
Should be 0 ohms.
If not replace it and be sure that you use the new harness that comes with the replacement fuse.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Whirlpool Quiet Partner II Repair (Dishwasher Repair)
by Scubacrazy56 3/1/2024 7:54:50 AM(UTC)
Need replacement control panel for Whirlpool Quiet Partner III (Dishwasher Repair)
by teewhile 1/18/2022 6:59:40 PM(UTC)
Whirlpool Quiet Partner II DU1145 (Dishwasher Repair)
by Guest 3/25/2021 6:39:10 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
Whirlpool Quiet PArtner III leaking underneath (Dishwasher Repair)
by KareeHunt 8/26/2020 8:26:37 AM(UTC)
Whirlpool Quiet Partner II Model DU1055XTVQ8 (Dishwasher Repair)
by mgandhd 4/29/2020 9:16:12 AM(UTC)
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Whirlpool Quiet Partner II (Dishwasher Repair)
by dresstheman 12/30/2017 5:17:12 PM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Whirlpool quiet partner ii won't start (Dishwasher Repair)
by Mac m 1/6/2015 5:53:21 PM(UTC)
Whirlpool Quiet Partner ii no start (Dishwasher Repair)
by captian23 12/20/2014 6:26:48 PM(UTC)
Whirlpool Quiet Partner III gets stuck on a Normal cycle (Dishwasher Repair)
by jessman1128 10/27/2014 9:09:10 PM(UTC)
Whirlpool Quiet Partner III help (Dishwasher Repair)
by sjde 9/10/2014 4:42:56 PM(UTC)
Whirlpool Quiet Partner III - Door is loose; drops quickly; doesn't stay down (Dishwasher Repair)
by ESticker 7/2/2014 4:11:59 PM(UTC)
by mgmills 6/8/2014 7:58:45 AM(UTC)
