Replacement parts for General Electric CTX18GICDRWW Refrigerator | AppliancePartsPros.comYes you are headed in the right direction.
I am going to assume that the evaporator fan runs when the compressor is running.
Also that if you manually defrost it that the unit runs OK till the evaporator coils clog up again with frost/ice.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 648 in Section 5) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 618 in Section 5) from the wiring and measure it for continuity.
If the heater is OK
Remove one wire to the defrost thermostat (Item 620 in Section 6) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Your element reading seems high as this would work out to a 72 watt heater.
