I cannot find any info on the given model number.
Are you sure it is DU1055XTVVQ0 or is it actually DU1055XTVQ0.
Here are the parts for an XTVQ0.
Replacement parts for Whirlpool DU1055XTVQ0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.comCould be the thermal fuse (Item 4 in Section 1) is blown.
Remove power from the unit.
Remove the fuse and check it with a meter.
Should be 0 ohms.
If not replace it and be sure that you use the new harness that comes with the replacement fuse.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
