stcarrigan@verizon.net
#1 Posted : Tuesday, February 7, 2012 7:12:29 AM(UTC)
dishwasher will not start. Has power. have replaced the fuse before. panel lights up when turned on but in section where time left is displayed there are 2 dashes?? does this mean I need to replace fuse again of is there something wrong with panel? also has message to add rinse aid?? this shouldn't cause it to not turn on??
Read more: http://forum.appliancepartspros...perba.html#ixzz1liGN00vk
http://forum.appliancepartspros.com
#2 Posted : Wednesday, February 8, 2012 3:57:32 AM(UTC)
I believe your model number should be KUDS01iJBL0.
I had to use upper and lower case because some idiot at Kitchenaide decided to use 1's and L's and i's in the model numbers.
Just venting as I personally cannot think of any reason to do this other than causing confusion.
Here are your parts.
Replacement parts for Whirlpool KUDS01IJBL0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Try removing power from the unit for a couple minutes to see if it will reset.
I cannot say if the rinse dispenser will cause this problem but if you take a look at the dispenser (Item 8 in Section 2), you will see that they did away with the level sensing as it caused more problems than it was worth.
Click on it's picture for more info and a Q&A section.
File Attachment(s):
KUDS01i.pdf (226kb) downloaded 7 time(s).
#3 Posted : Wednesday, February 8, 2012 7:24:01 AM(UTC)
Does anyone know what the 2 dashes in the status section on the front panel mean? dishwasher will not turn on. get error message on panel.
Kitchenaide dishwasher has no power. voltage and fuse is good (Dishwasher Repair)
by rnorton61 9/11/2014 3:45:57 PM(UTC)
Kitchenaide dishwasher-superba (Dishwasher Repair)
by stcarrigan@verizon.net 2/6/2012 9:01:08 AM(UTC)
kitchenaide dishwasher issues (Dishwasher Repair)
by luke54 10/29/2011 12:12:36 PM(UTC)
KitchenAide dishwasher not washing fully (Dishwasher Repair)
by sbrown 5/4/2010 5:39:19 AM(UTC)
Loud noise on Kitchenaide Dishwasher (Dishwasher Repair)
by gftaul 8/11/2009 10:50:02 AM(UTC)
