tbroton
#1 Posted : Monday, January 30, 2012 6:37:27 AM(UTC)
tbroton
Hopefully you can help -- My Kenmore washer seems to have problems with the fill-agitate step on the "TECH SHEET" the cam with the washer. The washer seems to stall and dribble water into the tub at steps 10/ 29/ 38 whereas at the other fill/agitate steps 4/17/25/53 it actually has a large inflow of water. Originally I thought the problem was the timer was stopping, and so installed a new timer, that wasn't it. I then thought maybe the Automatic Temp Control was hanging up, and bought that switch to no avail. so now my wife is getting progressively agitated, insisting on buying a new machine, and I really want to have fixed it. 3 of the four times it stalls on step angles (whartever that means) of 7.5 and the fouth is 7.
I've sent a copy of the Timing Chart cycle with the steps errant steps highlighted. Please help...
tbroton attached the following image(s):
