My oven quit working last night. It clicks when you turn on but does not get hot. Everything else works good. I tested voltage and had 240v across both elements when oven was set to bake. Not sure if both elements burnt out or I need a new clock. Any help would be greatly appreciated.
After further investigation I have no voltage to elements. From ground to either end I had 120v. Just figured that was 240v across it. Rookie mistake. Will order new timer board tomorrow.
