#1 Posted : Thursday, January 19, 2012 4:23:43 AM(UTC)
Is the evaporator (freezer) fan running?
It should be on when ever the compressor and it's fan are on.
What is the actual freezer temperature?
#2 Posted : Thursday, January 19, 2012 6:15:06 AM(UTC)
As far as I know it only fills once so water pressure should not cause non solid cubes.
ApplianceJunk
#3 Posted : Thursday, January 19, 2012 6:50:12 AM(UTC)
ApplianceJunk
Low water pressure to the ice maker will cause hollow cubes.
http://appliancejunk.com...s/index.php?topic=7136.0
#4 Posted : Thursday, January 19, 2012 10:29:46 AM(UTC)
Looks like hollow cubes could be due to low flow.
I took another look at the ice maker and it does fill from the far side away from the thermostat, so check that all the cube positions are filling with water.
#5 Posted : Friday, January 20, 2012 3:34:39 AM(UTC)
I would try replacing the water filter.
ppalkdup
#6 Posted : Friday, January 20, 2012 6:07:09 AM(UTC)
ppalkdup
Guest (4)
