dkschreiber
#1 Posted : Saturday, January 14, 2012 8:46:33 AM(UTC)
dkschreiber
My dishwasher is getting power but will not fill with water after pressing start. Appliance repairman examined and claimed we needed a new control board (breaker was tripped). We installed a new control board and this did not fix the problem. Any suggestions?
#2 Posted : Sunday, January 15, 2012 3:28:39 AM(UTC)
Here are your parts.
Replacement parts for General Electric GSD6660G00SS Dishwasher | AppliancePartsPros.com
Did you see how the repairman diagnosed the problem.
There are 3 devices involved with fill.
1. the control board.
2. the water valve.
3. the overfill switch.
Check the float on the overfill assembly. Sometimes it can get stuck in the up position. If it is then usually cleaning it will fix the problem.
If the overfill switch is being activated, check for 120 volts across the fill valve when it should be on.
If there is no voltage, check across the fill valve/overfill switch (they are wired in series).
If there is no voltage there, then the control board is probably toast.
If there is voltage, then check across the overfill switch. If there is voltage across the switch then the switch is shot.
If there is 120 volts across the fill valve then either the fill valve needs replacing or it's filter needs cleaning.
There is a screen filter built into the input side of the valve. Remove the valve from the unit and check/clean the screen filter.
Do not permanently remove the screen filter from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
