dishwash does not spin water- took spin arm out-not plugged- dish wash fill with water -then nothing - will drain- well dry- just not washing:D
you did not include a model # but by age this unit has a horizontal mount wash motor which is common to go bad,verify 110 volts at wash motor if you have power and it doesnt wash motor is bad
