StanRosputko
#1 Posted : Thursday, January 12, 2012 10:49:11 AM(UTC)
StanRosputko
Dishwasher'tube does not fill (it does some water). Also, nothing happens, however, when the cycle is cancelled, it drains.
I am inclined to replace the entire "Sum & Motor Assembly" (Part No. Part number: 8268413
I realize that this is the most expensive way, but it will probably make my life easier. Would you kindly provide me with any comments or suggestions?
Also, I would appreciate if you could give me some schematic how to remove the Assembly.
Thanks for your help and comments.
#2 Posted : Friday, January 13, 2012 1:03:50 PM(UTC)
Replacement parts for KENMORE 66517379301 | AppliancePartsPros.com
Not sure about the problem.
You said "[COLOR="DarkRed"]Dishwasher'tube does not fill (it does some water).[/COLOR]", this will have nothing to do with the pump.
When you say "[COLOR="DarkRed"]nothing happens[/COLOR]" is it really nothing or can you hear the pump running.
Perhaps after it does the fill, add a few quarts of how water. Just be careful that you do not over fill it.
Then see if it starts to wash.
If it does then you have a fill valve problem.
Since some water is entering the tub the most likely cause is a partially plugged screen filter on the input side of the valve.
Remove the valve and check/clean the screen. Do not permanently remove it as it is there to keep crud out of the valve which could hold it open and cayse a flood.
StanRosputko
#3 Posted : Saturday, January 21, 2012 5:15:44 PM(UTC)
StanRosputko
I would like to confirm/clarify, that at the start of washing “very little water fills the tube” this means some water. Regarding “nothing happens”, you are correct; I can hear the pump running.
Thanks for your help; also, can you show where the “fill valve” is located, and the part number.
Stan Rosputko
#4 Posted : Sunday, January 22, 2012 5:25:07 AM(UTC)
Here is the fill valve
Part number: AP3178611
If you go to the ********** parts site they have actual parts breakdowns.
Usually it is behind the kick plate on the left side.
StanRosputko
#5 Posted : Tuesday, January 24, 2012 7:22:47 AM(UTC)
StanRosputko
Based on your information, I was able to check and confirm that “Fill Valve” is one of the problems.
In addition, I have checked the “Lower Wash Arm” and found out that rotates freely but appears to have a significant horizontal “Play”. The question is how much gap it should have?
Furthermore, I filled with water up to the limit, to check if the upper and lower “Wash Arm” rotate during the washing cycle. Neither one work at all. Can you give a possible reason for not working?
Once again, thanks for your help
Stan Rosputko
Viking dishwasher repair (Dishwasher Repair)
by AngelaH 8/29/2023 8:48:21 AM(UTC)
Dishwasher Repair for GE profile (Dishwasher Repair)
by Guest 12/10/2022 11:15:25 AM(UTC)
Appliances Repair North York || Dishwasher Repair (Refrigerator & Freezer Repair)
by digitallab 7/8/2021 8:45:33 AM(UTC)
Bosch Dishwasher Repair Advice (Dishwasher Repair)
by Donan 9/20/2020 10:03:22 AM(UTC)
Samsung dishwasher repair (Dishwasher Repair)
by Cougar6069 5/5/2020 6:01:38 PM(UTC)
Dishwasher repair - kitchenaid briva KIDS36EPSS0 (Dishwasher Repair)
by magicmarc 1/8/2020 5:56:50 AM(UTC)
Bosch SHU9915UC/U11 Dishwasher repair (Dishwasher Repair)
by Yariet 11/4/2019 6:35:40 AM(UTC)
Bosch dishwasher repair (Dishwasher Repair)
by 66FSTbck 10/13/2018 7:34:04 AM(UTC)
Portable Dishwasher Repair (Dishwasher Repair)
by cliff10 1/7/2018 8:53:54 AM(UTC)
by maytagman17 9/26/2015 11:33:06 AM(UTC)
Dishwasher Repair - No water (Dishwasher Repair)
by maytagman17 9/26/2015 11:25:01 AM(UTC)
Whirlpool dishwasher repair question (Dishwasher Repair)
by asouth 1/18/2014 12:36:20 PM(UTC)
by sun47me 11/27/2013 4:46:52 PM(UTC)
Dishwasher repair.. (Dishwasher Repair)
by mssorcha51 9/11/2013 1:30:07 PM(UTC)
Bosch dishwasher repair help (Dishwasher Repair)
by jeanettekoster 10/30/2012 1:58:10 PM(UTC)
