I didn't know if you could help me figure out why my dishwasher stopped working all the sudden. It went through a normal, complete cycle then the next time I went to use it, it would not work at all. There is power to the unit but not to the Hi-limit thermostat. Would that part make the whole dishwasher not work? Any other ideas?
Here are your parts Replacement parts for KENMORE 66513832K601 | AppliancePartsPros.comThere is power to the unit but not to the Hi-limit thermostat. Would that part make the whole dishwasher not work? If you mean the hi-limit that is connected to the heater then the answer is no. More likely it is the thermal fuse on/at the control board in the door. Part number: AP4423189
If it is blown be sure to use the new wiring harness that comes with the fuse. Also you can click on the picture for more views and a Q&A section on this part. Click on the Q to see the A. |
THIS FORUM IS DEAD!!!!!!! |
