marvin44
#1 Posted : Tuesday, January 3, 2012 9:11:19 AM(UTC)
marvin44
door on oven was open - the oven clean button was pressed and set while the door was still open-- now the door will not close and the lock is set and lock light is flashing. How do I reset it?
marvin44
#2 Posted : Tuesday, January 3, 2012 9:23:19 AM(UTC)
marvin44
#3 Posted : Tuesday, January 3, 2012 12:55:15 PM(UTC)
Push and hold the oven light switch on the door frame. Push the Start button. Wait a few seconds and push the Cancel button. Release the oven light switch after the display will reset to the time mode.
marvin44
#4 Posted : Tuesday, January 3, 2012 5:39:58 PM(UTC)
marvin44
thanks it worked
#5 Posted : Tuesday, January 3, 2012 7:58:16 PM(UTC)
You are welcome. I'm glad you were able to fix it.
